How to run defination query in map series?
1598
02-09-2020 11:06 PM
AshishMishra
I'm working on Map Series where I'm using dynamic text to access the current layer information from the data base which working fine, but the issue which I'm facing now is I have one layer where I applied "definition query " from its properties. But in my map series that definition query is applicable to that particular area only, I want it should be applied to all my map series and it should work in loop.
Image you can see I have one column which shows the values in it.
in other image, I applied one definition query on the layer which is working fine for only one page where that condition is satisfied, but on other pages it is not working as I required.
please help
