SQL Server Geography Functions Intersect
2075
02-06-2020 02:37 AM
AlbertoLópez
Hi;
I have 2 layers (tables) in SQL Server/ArcGIS Enterprise Geodatabase and I have to intersect those layers and retrieve the areas of the intersections.
I am using a store procedure (SP) with geometrics functions in  SQL Server.
The layers in SQL Server are in Geographic Coordinate System GCS_ETRS_1989. But the results of the intersection and the areas returned by the SP  are not correct. The result I get doing the  intersect in  ArcMap does not give the same results.
The result in the SP is:
The result in ArcMap is:
I do not know if the problem is due to the Coordinate System.
This is the code. Any ideas?. Thanks.
USE [ENCE_SDE]goSET ansi_nulls ONgoSET quoted_identifier ONgoALTER PROCEDURE [ENCE_CARTO].[sp_XXX_getCatastroParcelaByCanton]
  @codCantonOr NVARCHAR (40)
AS
  BEGIN
    DECLARE @geometryCantonOr GEOMETRY;
    DECLARE @idMunicipio NVARCHAR(5);
    DECLARE @clamonSap   NVARCHAR(40);
    DECLARE @geogrpah AS GEOGRAPHY;
    DECLARE @cantonCortaParcial NVARCHAR(40);
    DECLARE @geometryCantonCortaParcial GEOMETRY;
    EXECUTE AS
      caller
    SET nocount ON;
    SELECT @geometryCantonOr =[Shape],
           @clamonSap=clamon_sap
    FROM   [XXX_SDE].[XXX_CARTO].[CANTONES]
    WHERE  canton_sap=@codCantonOr;
    SELECT @cantonCortaParcial = canton_sap,
           @geometryCantonCortaParcial=[Shape]
    FROM   xxx_sde.ence_carto.corta_parcial
    WHERE  canton_sap = @clamonSap;
    SELECT @idMunicipio= municipio_id
    FROM   [XXX_SDE].[XXX_CARTO].[MONTES]
    WHERE  ut_monte_sap =@clamonSap;
    IF (@cantonCortaParcial IS NULL)
    BEGIN
      SELECT objectid,
             refcat,
             (geography::STGeomFromWKB(
                    SELECT shape.Stasbinary()), 4326)).MakeValid().starea() AS suptotal,
             (geography::stgeomfromwkb(
                    SELECT (@geometryCantonOr.STIntersection(shape)).STAsBinary()), 4326)).starea() AS supinter,
             LEFT(refcat, 5)        AS municipio
      FROM   [XXX_SDE].[XXX_CARTO].[CATASTRO_PARCELA] WITH(INDEX(s188_idx))
      WHERE  @geometryCantonOr.stintersects(shape)=1
      AND    LEFT(refcat, 2)=LEFT(@idMunicipio, 2)
    END
    ELSE
    BEGIN
      SELECT objectid,
             refcat,
      WHERE  @geometryCantonCortaParcial.stintersects(shape)=1
    END
    end‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
The first thing that comes to mind when talking enterprise geodatabases and different results between SQL outside of ArcGIS clients and results from within ArcGIS clients are versioned data.  If the data is versioned, make sure you are running your SQL outside of ArcGIS on the same versioned data as what is being used within ArcGIS.
