Send Error: A date conversion error has occurred
1419
01-24-2020 10:20 AM
AhjungKim4
We are migrating a feature service and a survey from ArcGIS Online to ArcGIS Enterprise 10.5.  I moved the feature service and was able to publish the form to Portal.  When I test submitting data as a user, it fails with "a date conversion error has occurred" error.  Does anyone know what causes this error?
Tags (1)
AhjungKim4
I removed all the date type questions, but I am still getting the error.
JamesTedrick
Esri Esteemed Contributor
Hi Ahjung,
Are you using a hosted feature service or a feature service tied to an enterprise geodatabase?  Given that this is probably specific to form design and feature service, it might be better to work through Esri Technical Support to address this issue.
