I am making a buffer in an ArcGIS Pro Add-in. How do I set the units? GeometryEngine.Instance.Buffer() takes a geometry and a distance. How do I get the map's units so I can choose the metric or US value I give the buffer method?
Hi Steve,
You may want to look at the ArcGISDynamicMapServiceLayer
Example
private void theArcGISDynamicMapServiceLayer_Initialized(object sender, EventArgs e) { // Get the ArcGISDynamicMapServiceLayer. ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer theArcGISDynamicMapServiceLayer = null; theArcGISDynamicMapServiceLayer = (ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer)sender; // Get and display the ArcGISDynamicMapServiceLayer.Units information. string theUnits = theArcGISDynamicMapServiceLayer.Units; TextBlock_Units.Text = theUnits; // Get and display the ArcGISDynamicMapServiceLayer.SpatialReference information. ESRI.ArcGIS.Client.Geometry.SpatialReference theSpatialReference = theArcGISDynamicMapServiceLayer.SpatialReference; if (theSpatialReference != null) { int theWKID = theSpatialReference.WKID; string theWKT = theSpatialReference.WKT; if (theWKID != 0) { TextBlock_SpatialReference.Text = "WKID: " + theWKID.ToString(); } else { TextBlock_SpatialReference.Text = "WKT: " + theWKT; } } }
