Copying item with the python API - index error?
1357
01-22-2020 01:39 AM
MathisGaarde_Kristensen
Im trying to copy a feature service from one AGOL account to another. The name is unique. When using the pyton API Im getting the error:
Unable to add feature service definition.
The operation failed because an index or statistics with name 'Tennpunkt_nummer_unidx' already exists on table 'db_4868.user_4868.Gatelys_Webmap_WFL1_TENNPUNKT'.
I've tried cloning to different accounts but I always get the same error. This worked fine last year in October/November. I've tested using the arcgis api 1.62 and 1.7, with the same result.
Im using GIS.content.clone_items() and have tested with copy_date=True and False.
Any help or advice is appreciated!
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Mathis,
Try the following tool:
https://community.esri.com/docs/DOC-13762-copy-content-between-portals
The Copy Services and Copy File Based Items tools will work for ArcGIS Online, however, the Copy Maps and Applications tool will not.
Hi Jake,
I get the same error using this tool. I see in the code that the cloning is also done using "content.clone_items".
DataLoader
Hi Mathis,
Just wondering if you managed to solve this issue, I am getting the same '_unidx' already exists error message when trying to clone content.
RandallBrown
Any update on this?  We are having the same problem cloning a feature service.
