Inbox - Spatial query
751
01-20-2020 10:35 AM
JayH
Hello all,
Is there any way that I can add spatial control for Inbox?
For example, my survey is built on the address points in the province which has more than 1M count. I've already set up SQL query in the survey so it only filters where surveyStatus = null (then surveyors need to go check), but there will still be too many records.
I hope I can set up spatial query so that Inbox display address points that are within 100 m (or any specified distance) of surveyor's location. Is this functionality feasible in survey 123? If not, are there any limit on the records that can be in Inbox?
JayH
I found the information regarding 'Spatial filter' (Prepare for editing existing survey data—Survey123 for ArcGIS | Documentation ). This should work for my case...
