Global value can't be assigned inside the expression in python toolbox
3674
7
01-17-2020 04:26 AM
AarthiBalamurugan1
I am trying to call the global value 'total_rows' inside the expression. But I am getting an error.
and my code is
def execute(self, parameters, messages):
"""The source code of the tool."""
   inputdataset = parameters[0].valueAsText #getting the parameters
   count_rows = arcpy.GetCount_management(inputdataset)
   total_rows = int(count_rows.getOutput(0))
expression = '''
   def getCitation(p_dataset_id):
      global total_rows
      if(total_rows == 5):
            ds=PanDataSet(p_dataset_id)
   return ds.citation
RandyBurton
Using globals in a Python toolbox or script tool is a bit tricky.  The toolbox/script creates a number of instances during function calls.  It is best to declare a global in getParameterInfo as this function appears to be called only once.  An example of a toolbox script that uses "junk" as a global variable is:
import arcpy
class Toolbox(object):
    def __init__(self):
        self.label = "Toolbox"
        self.alias = ""
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
        self.label = "Tool"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self):
        global junk
        junk = None
        param0 = arcpy.Parameter(
            displayName="Something",
            name="something",
            datatype="GPString",
            parameterType="Required",
            direction="Input"
        params = [param0]
        return params
    def isLicensed(self):
        return True
    def updateParameters(self, parameters):
        global junk
        junk = "XYZ"
        return
    def updateMessages(self, parameters):
        return
        global junk
        arcpy.AddMessage("The value junk is: " + junk)
        return
For more discussion see the following:
Using Global Variables in Python Toolbox?
Python toolbox tool objects do not remember instance variables between function calls?
AarthiBalamurugan1
Inside the expression the global value is not working. I want to get the number of row values inside the expression.
DanPatterson_Retired
expression = '''
   global total_rows
   total_rows=5
   return ds.citation‍‍‍‍‍‍‍‍‍‍‍‍
so this didn't work either?
But I am not sure what it is the script is doing since there is nowhere in the script that collects information to compare to total rows
AarthiBalamurugan1
No It didn't work as well. I am getting the same error. If it is outside the expression it works.
Right now I am just testing the code whether the global values can be assigned inside the expression.
I am sending the dataset id value to the server to collect the data. Within 30 seconds the server can handle 60 data if it is more than that it stops working.
So I want to get the total number of rows and if it's more than 60 rows I want to delay the processing.
you need to assign an initial value to the global somewhere, like outside the def in your enclosing expression
RandyBurton
Did you try something like indicating that total_rows was a global in the "execute" function (line 3) below:
   global total_rows # indicate that total_rows is a global
expression = '''
      global total_rows
   return ds.citation
I'm also puzzled by the indentation in the code snippet you posted.  Is the "expression" section (lines 9 -17) part of the "execute" function?  It may not be indented properly.
Luke_Pinner
MVP Regular Contributor
It's a string expression and is evaluated outside the scope of your current code so has no knowledge about any of your variables.
You need to insert the actual value into the string:
class YourTool(object):
    def __init__(self):
        etc...
        etc...
        inputdataset = parameters[0].valueAsText  # getting the parameters
        expression = '''
  total_rows = {}
      return ds.citation
'''.format(total_rows)
Note - you can't indent the expression, or it won't be valid python syntax when the tool evaluates it - IndentationError: unexpected indent.  If you want your code to look cleaner and have the expression indented, you can use inspect.cleandoc(expression)
inspect — Python 2.7 documentation
inspect — Python 3.8 documentation
inspect.cleandoc(doc)
Clean up indentation from docstrings that are indented to line up with blocks of code.
All leading whitespace is removed from the first line. Any leading whitespace that can be uniformly removed from the second line onwards is removed. Empty lines at the beginning and end are subsequently removed. Also, all tabs are expanded to spaces.
import inspect
    def __init__(self):
        etc...
        etc...
        expression = inspect.cleandoc('''
                total_rows = {}
                    return ds.citation
        '''.format(total_rows))‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
