ApplySymbologyFromLayer works in the Python window on ArcGIS Pro, but not in a ToolBox
1000
01-17-2020 07:39 AM
Gustavo_Souza
I am having this issue for months now, I am keeping up with the topics about it here, but no solution yet.
ApplySymbologyFromLayer does not work in a Python Toolbox. It does work on the Python window, but in a toolbox it does not show any result. No error, no warnings, just no effect at all.
My Python toolbox code is decent sized, it has a number of tools and none of them have any issue, does a lot of different tasks, but for some reason, it can't Apply Symbology From Layer. When the line runs, I can see the layer being locked for a while, and then the code complete without any results.
There is one workround, which is constantly suggested here, and I was using successfully:
new_lyr_file = arcpy.mp.LayerFile(symbology_layer)
new_lyr = new_lyr_file.listLayers()[0]
old_lyr = aprxMap.listLayers(inputlayer)[0]
old_lyr_name = old_lyr.name
new_lyr.updateConnectionProperties(new_lyr.connectionProperties, old_lyr.connectionProperties)
new_lyr.name = old_lyr_name
new_lyr_file.save()
aprxMap.insertLayer(old_lyr, new_lyr_file)
aprxMap.removeLayer(old_lyr)
Until i noticed that it screws up the URL in the Data Source. It brings some issues when trying to upload the Map to AGOL.
The funny part is that both
- arcpy.management.ApplySymbologyFromLayer(Input, Symbol)
and
lines of code works perfectly when using the Python Windom on ArcGIS Pro.
Any ideas why the code would run in the Python Window but not on the Toolbox?
Luke_Pinner
MVP Regular Contributor
I've never used ApplySymbologyFromLayer in a toolbox so can't comment on the issue, but what I do that works is set the symbology property of output layer parameters, and the symbology is automagically applied when the output parameter is set at the end of my execute method:
class Tool(object):
    def getParameterInfo(self):
        params = []
        params[0] = arcpy.Parameter(
            displayName="Output Raster Layer",
            name="out_raster_lyr",
            datatype="GPRasterLayer",
            parameterType="Derived",
            direction="Output")
        params[0].symbology = r'path\to\symbology.lyrx'
        return params
    def execute(self, parameters, messages):
            layer = do_something_and_return_a_layer()
            arcpy.SetParameter(0, layer)  # Layer gets added to the map with symbology applied without me manually applying it.
