identify if Point within Polygon
3316
01-14-2020 12:41 AM
Kae_WoeiKang
I have a Point which obtained through a long press MotionEvent.
Point mapPoint = mMapView.screenToLocation(new android.graphics.Point(Math.round(e.getX()), Math.round(e.getY())));
However, I need to verify if the point is lying within the polygon. I can't find any API in Geometry which allows me to check if the point is located inside the polygon.
Any idea?
ShellyGill1
Hi Kae,
The GeometryEngine class has lots of geometry-on-geometry spatial operations - you can try the GeometryEngine.contains static method - GeometryEngine (ArcGIS Runtime SDK for Android 100.7.0) . There's a sample that demonstrates this method, along with a lot of other spatial relationships like intersects, within, etc - Spatial Relationships | ArcGIS for Developers .
Hope this helps,
Shelly
ShellyGill1
Hi Kae,
Hope this helps,
Shelly
Kae_WoeiKang
Yes, Thanks! I just found the functions which works like magic.
boolean isContain = GeometryEngine.contains(p, ltLn);
