How to delete related records in Web Mapping Application
1340
01-07-2020 08:01 AM
MaiSwasdichira
Hi everyone,
I wonder if you can please help with my question. I created a web mapping application using the Inspect Hydrants - ESRI tutorial. There were two related tables associated with the hydrant features. I was able to use the Edit Widget to add/edit the Hydrant features, and the two related tables. However, when it comes to deleting data, there is a problem with it.
1) I could only delete a hydrant feature but not its related records. Therefore, there were a bunch of orphan records left on the two related tables.
2) I then wanted to delete those records but there was no option to delete records from the two table directly.
Am I miss something when it come to deleting features with their related data?
Thanks for your help.
M
Alber_Verster
Hi Mai,
I wonder if this is not a configuration of the Edit Widget issue. Have you had a look at the workaround?
FAQ: Is it possible to add or delete related records when editing a related table in ArcGIS Online M...
Alternatively, removing the records using ArcGIS Desktop might be a suitable workaround, if the above solution does not answer your question.
Hope this helps.
