How to get user logged in without passing through login dialog in javascript ?
1081
12-27-2019 07:05 AM
LaurentDuruflé
From sample provided here I would like to login using a specific login/password embedded in my javascript code without any login dialog (login will be transparent to user). Any idea how to customized the JS code from this sample to achieve this objective ?
sample using login dialog (from ArcGIS API for JavaScript Sandbox 😞
<script>
  var map, cred = "esri_jsapi_id_manager_data"; // cookie/local storage name
  require([
    "dojo/_base/unload",
    "dojo/cookie",
    "dojo/json",
    "dojo/parser", "esri/config", "esri/IdentityManager", "esri/layers/FeatureLayer",
    "esri/map",
    "dijit/layout/BorderContainer",
    "dijit/layout/ContentPane",
    "dojo/domReady!",
  ], function (baseUnload,
    cookie,
    JSON,
    parser, esriConfig, esriId, FeatureLayer,
    Map){
    // store credentials/serverInfos before the page unloads
    baseUnload.addOnUnload(storeCredentials);
    // look for credentials in local storage
    loadCredentials();
    parser.parse();
    esriConfig.defaults.io.proxyUrl = "/proxy/";
    map = new Map("mapCanvas", {
      basemap: "topo",
      center: [-120.723, 35.165],
      zoom: 12
    //add the secure service - token is required
    var secureLayer = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/SaveTheBay/FeatureServer/0",
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields: ["*"]
    map.addLayer(secureLayer);
    function loadCredentials(){
      var idJson, idObject;
      if (supports_local_storage()) {
        // read from local storage
        idJson = window.localStorage.getItem(cred);
      else {
        // read from a cookie
        idJson = cookie(cred);
      if (idJson && idJson != "null" && idJson.length > 4) {
        idObject = JSON.parse(idJson);
        esriId.initialize(idObject);
      else {
        // console.log("didn't find anything to load :(");
    function storeCredentials(){
      // make sure there are some credentials to persist
      if (esriId.credentials.length === 0) {
        return;
      // serialize the ID manager state to a string
      var idString = JSON.stringify(esriId.toJson());
      // store it client side
        // use local storage
        window.localStorage.setItem(cred, idString);
        // console.log("wrote to local storage");
      else {
        // use a cookie
        cookie(cred, idString, {expires: 1});
        // console.log("wrote a cookie :-/");
    function supports_local_storage(){
      try {
        return "localStorage" in window && window["localStorage"] !== null;
      } catch (e) {
        return false;
  </script>
Tags (1)
