Points along a multipart polyline feature based on a field value
742
12-15-2019 06:57 PM
UmaMahesh1
I have to generate points along a line based on a field [PrkngSpacs] value. I need to do this for around 10k lines in a multipart polyline feature. I checked few tools available that generates points based on distance and intervals. They are working fine with single line, but i do not know how to make them loop through each of my attribute values in [PrkngSpacs] field and create same number of points.  Any help in how to accomplish this is much appreciated.
DanPatterson_Retired
You could experiment with a small sample and convert the multipart to singlepart, do the densification, then Dissolve back to multipart after the densification.
JoshuaBixby
MVP Esteemed Contributor
It would be helpful if you could elaborate on:
If there are geoprocessing tools that only work on single-part geometries and not multi-part geometries, there may be defects involved.
UmaMahesh1
Thank you Dan and Joshua for responding to my query. I could accomplish my task by using "Create points on Polylines with Arcpy" toolbox developed by Ian.
