Tapping on Point Doesn't Open
794
12-13-2019 08:39 AM
NinaDiaz
I have a map set up so that when you tap on a point, you can click on a link that takes you to a 123 Survey. Everything seems to work great and it's set up for offline collection. However, when the wifi cuts off during field collection, the map and points load fine but nothing happens when you tap on a point. I know it's the wifi that's affecting it because I tested it a few times by manually turning it off and on and with wifi it works.
Any thoughts? This is on an ipad.
