ArcMAP error in logwrite 91: Object variable or With block variable not set
3720
8
12-12-2019 11:13 AM
MattValencia
I have an issue launching ArcMap.exe and loading .mxd
I am prompted with an error on launch and exit of ArcMAP
Error in LogWrite:
I am using ArcGIS ArcMAP 10.3.1 on Windows 10 ver 1803
suspect is installation of autocad related software, possible dll issues?
What I have tried:
ArcGIS 10.3.1 Repair
ArcGIS 10.3.1 uninstall / directory cleanup + registry cleanup / reboot / re-install
creating new windows 10 profile
Anyone have any information, ideas / suggestions would be very helpful.
MichaelVolz
Esteemed Contributor
Did you have an earlier version of ArcMap installed on this machine?
MattValencia
Hello Michael
No I do not have an earlier version of Arcmap installed
Just an install of ArcGIS Desktop 10.3.1
ArcGIS_Desktop_1031_145699.exe
C:\Program Files (x86)\ArcGIS\Desktop10.3
MichaelVolz
Can you uninstall the AutoCAD related software from the machine, at least temporarily to see if that gets rid of the error?
Can you also try the same install on a different computer?
MattValencia
Hello Michael
All AutoCAD related software removed / uninstalled
Same exact error!
Error on load of ArcGIS ArcMAP 10.3.1
Error in LogWrite:
Error after exiting of ArcGIS ArcMAP 10.3.1
Error in LogWrite:
MichaelVolz
Can you try option B to install ArcMap 10.3.1 on another computer that has never had AutoCAD software installed on it?
Do you not have the ability to use a newer version of ArcMap (it's at 10.7.1) or even Pro?
MattValencia
 I have AutoCAD and ArcMap 10.3.1 installed on my machine, and there are many others here as well that have autoCAD 2020
NO
I have uninstalled ArcMAP 10.3.1
uninstalled all autoCAD programs
rebooted and re-installed ARcMAP 10.3.1 on machine
Same Error
MichaelVolz
So you already have computers setup at your org that have ArcMap 10.3.1 and AutoCAD 2020 working together?  I don't use AutoCAD but I did not think a new version of AutoCAD such as 2020 would be compatible with that old a version of ArcMap.  Does ESRI or AutoCAD have a compatibility matrix to show that this setup is supported?
MattValencia
I have a computer here that has just ArcMap 10.3.1
when i start ArcMAP 10.3.1 i get an error
Error in LogWrite:
Maybe there is a component i am missing, library?
