Sort List When Selected on Map
1247
12-11-2019 02:08 PM
RogerCleaves1
I'm wondering if it's possible to sort your list based on what was selected, via a trigger possibly?
The current app I have wired up allows for the list to filter based off of the extent of the map, and when you select a point in the map, it highlights the item in the list. However, sometimes that item may be way down the list and require the user to scroll to find it.
Example of the App
Is there a way to sort this list upon selection so the highlighted feature ends up at the top?
Thanks!
Roger
DavidMartinez
Hi Roger,
This issue was discovered a couple of weeks ago and we are trying to fix it for the final release.  The list should show the record selected without having to scroll.
David
WillArellano
I am also having this issue of the list not scrolling to the feature selected on the map. I thought I was doing something wrong. This is super annoying and makes the application look like it isn't functioning properly. Is there a fix for this?
UPDATE: So I figured out that the list isn't scrolling because when I click on a point in the map, the polygon that the point is within also gets selected. When there is no polygon overlaying the point, the list scrolls as expected. Not sure how to make the polygon unselectable, but at least now I know what is causing the issue.
