UdateCursor with Select By Location
5990
17
12-11-2019 12:05 PM
2Quiker
I am trying to do a select by location and then update the selected features, seems easy enough but i am see to get it figured out. Basically i want to update only the parcels that are within the City limits layer and update the 4 fields. I have tried different variations but i can't seem to get to work. I don't get any errors and also doesn't stop. I would appreciate any help.
Here is what i have.
import arcpy
from datetime import datetime as d
startTime = d.now()
start_time = time.time()
arcpy.env.workspace = "C:/Temp/blah.gdb"
fc1 = "C:/Temp/blah.gdb/Parcels"
CITY = "C:/Temp/blah.gdb/City_Limits"
with arcpy.da.UpdateCursor(fc1, ['field1','field2','field3', 'field4']) as cursor:
    for row in cursor:
        #Select all parcels within the city limits layer
        arcpy.SelectLayerByLocation_management(fc1,"HAVE_THEIR_CENTER_IN", CITY)
        result = arcpy.GetCount_management(fc1)
        row [0] =  "IN CITY"
        row [1] =  "IN CITY"
        row [2] =  "IN CITY"
        row [3] =  "IN CITY"
        cursor.updateRow(row)
    del row, cursor
print('Done')
try:
    print ('(Elapsed time: ' + str(d.now() - startTime)[:-3] + ')')
except Exception as e:
    # If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    print ("Line %i" % tb.tb_lineno)
    print (e.message)
by Anonymous User
Not applicable
Hi 2 Quicker (and not Dan ) <edited>
Nice script, a couple of things that should get it working:
  • move the selection outside of the "with" statement
  • you were not using the "result" of the count in this snippet, so i included some more print statements to give more feedback
  • the update cursor now runs on the selection rather than the full data set
if this doesn't work then i would suggest
  • adding in a unique identifier if one doesn't already exist
  • building a list/set from the selection
  • iterating over fc1 and updating the fields "if <uniqueID> in <list>"
If you like i can do up a skeleton of this option as well.
Hope this helps and good luck
Michael
import arcpy
startTime = d.now()
selection = arcpy.SelectLayerByLocation_management(fc1, "HAVE_THEIR_CENTER_IN", CITY)
numberoffeaturesfc1 = arcpy.GetCount_management(fc1)
result = arcpy.GetCount_management(selection)
count = 0
def findwhatsincity():
    global count
    with arcpy.da.UpdateCursor(selection, ['field1', 'field2', 'field3', 'field4']) as cursor:
        for row in cursor:
            # Select all parcels within the city limits layer
            row[0] = "IN CITY"
            row[1] = "IN CITY"
            row[2] = "IN CITY"
            row[3] = "IN CITY"
            count += 1
        del row, cursor
    print('Done')
try:
    print ('Starting Script @ ' + startTime)
    findwhatsincity()
    print ('Number of features in ' + str(fc1) + ": " + str(numberoffeaturesfc1))
    print ('Number of features in selection: ' + str(result))
    print ('Number of features processed: ' + str(count))
    print (e.message)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
I don't see you using any 'layers' (aka, lyrx files) but featureclasses.
see code examples in
Make Feature Layer—Data Management toolbox | ArcGIS Desktop
Select Layer By Location—Data Management toolbox | ArcGIS Desktop
2Quiker
I tried the following nothing happens, no error and the fields don't get updated.
import arcpy
startTime = d.now()
arcpy.MakeFeatureLayer_management(fc1, "fc1tLyr")
arcpy.MakeFeatureLayer_management(CITY, "CityLyr")
    for row in cursor:
        arcpy.SelectLayerByLocation_management("fc1tLyr","HAVE_THEIR_CENTER_IN", "CityLyr")
        result = arcpy.GetCount_management("fc1tLyr")
        row [0] =  "IN CITY"
        row [1] =  "IN CITY"
        row [2] =  "IN CITY"
        row [3] =  "IN CITY"
    del row, cursor
print('Done')
try:
throw in a print statement to see how many were selected
JoeBorgione
But if none are actually selected, would all get updated?
actually, I am not even sure why the selectbylocation is within the loop in the first place
and
Editor—Data Access module | ArcGIS Desktop
you may be right about the edit session since Pro ISN'T open (see the code samples at the end)
I suspect 1 selectbylocation with the featurelayer, then the edit session, then the cursor stuff with lots of print statements thrown in to see w.t.h. is going on
JoeBorgione
Maybe you need to open an edit session?  Editor—Help | ArcGIS Desktop
2Quiker
The data is in file database i didn't think i need to start an edit session.
JoeBorgione
Yeah, typically not....
by Anonymous User
Not applicable
Michael
import arcpy
startTime = d.now()
count = 0
    global count
        for row in cursor:
            row[0] = "IN CITY"
            row[1] = "IN CITY"
            row[2] = "IN CITY"
            row[3] = "IN CITY"
            count += 1
        del row, cursor
    print('Done')
try:
    findwhatsincity()
