Arcgis Runtime Xamarin forms - Android = No Map
1395
12-10-2019 05:30 PM
DavidDoyle
Im using Visual Studio 2017, arcgis runtime 100.6
Im looking at making a xamarin forms cross platform app with .net runtime.  Im looking at making android, ios and windows.
i have downloaded the .net runtime  sdk from esri and installed.
I created the visual studio project using the arcgis runtime app (xamarin.forms....
It creates it perfect.  I can run the uwp and it works and i see the map.
if i then try and run the android app it loads.  but i get a grey window where the map should be.  and the very bottom a white status bar says Powered by Esri.
I have tried numerous android devices for testing...all show a grey window where the map should be.
i then tried standalone android, i tried just creating the xamarin and using nuget to get the arcgis runtime.  I always get a grey window.
But it works in UWP.
Is there something im doing wrong.  I followed the guide. I just cant think what is wrong.
David.
Sparky1
David, did you ever get a solution for this? I have exactly the same issue!
