Highlight multiple features from different layers when single feature is selected
1230
12-10-2019 12:27 AM
irtizahussain
Hi.
I need to to highlight multiple features from different layers when a single feature is selected! For example, I have several points and polylines. When the point is selected, I would like the polyline that is pass through it highlighted as well.
If it is possible any suggestions are appreciated!
Thanks.
RobertScheitlin__GISP
Irtiza,
   You would have to add a listener to the map.infoWindow > set-features event and then check to see if the features layer name is your point layer name and if so then take that feature geometry and execute a query on the polyline layer to select the intersecting line.
