Download File from Geoprocessing Service by URL
2855
12-10-2019 06:27 AM
LukasWürsch
New Contributor III
I want to download a file created by a Geoprocessing Service. For testing, I created a Service from the script below. The script is having a user supplied input of type String and a derived output of type File.
import os
input_from_client = arcpy.GetParameterAsText(0)
file = open("testfile.txt","w")
file.write(input_from_client)
file.close()
arcpy.SetParameter(1, file)
I thought that I can simply set the created file as output parameter (arcpy.SetParameter) and would then be able to download it with the returned url.
Yet, when running the service with the REST interface, it returns an incorrect url (note the <_io.TextIOWrapper name='testfile.txt' mode='w' encoding='cp1252'> part in the end):
 "paramName": "File",
 "dataType": "GPDataFile",
 "value": {
   "url": "https://[nameofserver]/gis/rest/directories/arcgisjobs/excelreportservice_gpserver/j3ddfaa172cc7477288253c965e3c3aba/scratch/<_io.TextIOWrapper name='testfile.txt' mode='w' encoding='cp1252'>"
Any ideas how I can get the correct download url?
Would be very thankful for support on this.
Regards, Lukas
JonathanQuinn
Esri Notable Contributor
You'll need to get the path from the TextIOWrapper class:
Your etParameterAsText line would be
arcpy.SetParameter(1, file.name)
JonathanQuinn
LukasWürsch
New Contributor III
Thank you for the reply. I changed the service the way you suggested and this could remove the text wrapper from the url. Now I am getting this url
https://[nameofserver]/gis/rest/directories/arcgisjobs/excelreportservice_gpserver/j08439162107846f99bc04281f6aa0a36/scratch/test.txt
I had a look at the server and noticed that the scratch folder is empty. Do I have to change the script so that the textfile is put to the scratch folder?
LukasWürsch
New Contributor III
I think i figured it out,
The file has to be created in the scratch folder using arcpy.env.scratchWorkspace variable, then it can be downloaded with the returned url as expected
import os
file = open(arcpy.env.scratchWorkspace+ "/" + "test.txt","w")
file.close()
Arne_Gelfert
Thanks, that was very helpful!
