Location error
892
12-07-2019 01:08 AM
JumaKhudonazarov1
Can someone help? I cant get the location  on survey123.
Tags (1)
KoryKramer
Esri Community Moderator
You should ask this in the Survey123 for ArcGIS‌ group.  Hopefully somebody there will be able to help!
JuanSantos
Hi @Juma Khudonazarov
It depends on the version you have of the app, for example, I leave you some updates:
  • Update of 09/26/2019: Fixed an error that caused the geopoint calculations that use values in a main layer not to be applied after the first repetition.
  • In the update 01/31/2019 connect 3.2.196: Various corrections of location and internationalization errors and improvements have been made.
  • Update of 11/21/2017 version 2.5.44. when using a Bluetooth R1 Trimble GNSS receiver
The link: Novedades de Survey 123
Other link: What's new in Survey123
Hope this can help you.
