Issue deploying web app created using Developer Edition
2506
12-04-2019 10:24 AM
NDFAdmin
I recently developed a custom web application using Web AppBuilder SDK. I downloaded and unzipped the web app files and put them on my web server (IIS). However, when I go to access the application I only get the loading screen and eventually the connection times out and says the site can't be reached. It seems to be an issue with setting up a proxy, but I wanted to make sure that there wasn't something I was missing. Has anyone else had a similar issue?
Aaron
NDFAdmin
Thank you, that solved the issue.
RobertScheitlin__GISP
What errors are presented in the browsers web console?
NDFAdmin
I'm getting a 404 not found error.
So that points to two different issues you have.
  1. You have not registered the woff and woff2 mime types with your web server. Set mime types for web fonts in IIS » Coding Still
  2. You have your portal url using https and your web server is not setup to support https. You need to open the config.json for that app and change the portalUrl to http
NDFAdmin
