XML file - problem with importing to ArcGIS Pro
1084
11-30-2019 03:25 AM
AnitaMakowska
I have problem with following file to import it using Interoperability extention. It works but with some comments while I am choosing to ignore application schema as well as I set manually GML Future Elements. But still points are on a wrong location. Can you pls check the file if it works with your program?
Note: the file is too big do upload it so I transfer it via wetransfer: https://we.tl/t-GxQXC6wzw4
