XML Workspace Document
769
11-26-2019 09:58 AM
AbiDhakal
Hello GIS friends,
I have imported an XML Workspace Document that I was using in ArcMap into ArcGIS Pro, but I'm having a problem with it. It imports fine and all that, however when I go to create a point feature it does not create features in Alabama. So I open up ArcMap as it is my go to software and bring the point feature class from the newly imported XML Workspace Document and try to insert a point feature in ArcMap as well, but it says the coordinates are out of bounds. I wonder what is going on and how I can fix this.The projection information on the feature class is:
Projected Coordinate System:    WGS_1984_Web_Mercator_Auxiliary_Sphere
Projection:    Mercator_Auxiliary_Sphere
False_Easting:    0.00000000
False_Northing:    0.00000000
Central_Meridian:    0.00000000
Standard_Parallel_1:    0.00000000
Auxiliary_Sphere_Type:    0.00000000
Linear Unit:     Meter
Geographic Coordinate System:    GCS_WGS_1984
Datum:     D_WGS_1984
Prime Meridian:     Greenwich
Angular Unit:     Degree
Thank you,
Abi
Tags (1)
