How can I access the memory-based workspace via the SDK?
1843
11-22-2019 04:09 PM
MichaelReutebuch1
I've read the page on writing geoprocessing output to memory and saw an example on the SDK Github using the memory-based workspace, but all the examples either use Python or only show writes, not reads.
How can I access feature classes in memory using the SDK (currently using 2.4)?
JamieKelly1
Not sure if you found out how to access an in memory feature class, but it took me quite a while to figure it out.  And it was all because you need to call the build method of the schemabuilder object first.  I doesn't exist until you call Build.
Then it is as easy as  *** memGeoDatabase.OpenDataset(Of FeatureClass)("Deeds") *** memGeoDatabase here is just a GeoDatabase object that is my in memory geodatabase.
