Label Text moving out of callout with rotation
912
11-22-2019 10:19 AM
BryceBarth
When you have a callout box with a label text, the text fills in the box perfectly.  However if you are using map series in the layout view and the data frame is rotated to the orientation of the individual pages, such as with the strip maps.  The text shifts out of the callout box where the greater the rotation of the page the farther offset the text becomes.  if the page is oriented at perfect east west or north south the text is positioned perfect but if the page is rotated at all from those positions then the text is offset.  This happens even if you convert the labels into annotation and try to manually rotate the label.  Is this a bug or is there some way to correct this.
WendyHarrison
Hi Bryce,
I've been unable to reproduce the issue here. The easiest way to resolve whether something is set wrong or it is a bug, is to log an issue with Technical Support.  If it is a bug they can get the repro case through to me and we can look at it.  If something is set wrong they will be able to assist in straightening it out.
thanks
Weny
