Apply LayerX Files from Portal
1758
11-25-2019 03:33 AM
Vidar
I can store a layerX file in Portal and access from my Pro Client with it's item ID:
Item testLayerLryx = ItemFactory.Instance.Create(lyrxId, ItemFactory.ItemType.PortalItem);
Great. However - can I use this object to apply symbology from the layerX entity to an existing layer already loaded into Pro. It looks tricky as the constructor only seems to accept a filepath and a CimLayerDocument.
LayerDocument layerDoc = new LayerDocument();
- but I may going down the wrong path in any case.
Also, the LayerFactory only makes layers, but I can't see anything similar for layer files.
Anyway, any help - much appreciated.
GKmieliauskas
Hi Simon,
To apply symbology from lyr/lyrx file you need to use geoprocessing:
var parameters = Geoprocessing.MakeValueArray(featLayer, lyrFilePath);
var gpResult = Geoprocessing.ExecuteToolAsync("ApplySymbologyFromLayer_management", parameters,
   null, null, null, GPExecuteToolFlags.GPThread);
UmaHarano
Hi Simon,
You can create a layer from an item using this overload of the CreateLayer method
public Layer CreateLayer(
   Item item,
   ILayerContainerEdit mapOrGroupLayer,
   int index,
   string layerName
You can apply your lyrX file's symbology to a layer in the active map using code similar to the snippet below:
QueuedTask.Run( () => {
                Item portalLayerLryxItem = ItemFactory.Instance.Create(lyrXPortalItemID, ItemFactory.ItemType.PortalItem);
                var featureLayer = LayerFactory.Instance.CreateLayer(portalLayerLryxItem, MapView.Active.Map);
                var lyrDocFromLyrxFile = new LayerDocument(featureLayer);
                var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
                //Get the renderer from the layer file
                var rendererFromLayerFile = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMSimpleRenderer;
                var featureLayerToApplySymbologyTo = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(f => f.Name.Contains("Cities")).FirstOrDefault(); ;
                //Apply the renderer to the feature layer
                featureLayerToApplySymbologyTo?.SetRenderer(rendererFromLayerFile);
Uma
