How to generate a column based on raster data?
674
11-21-2019 02:19 AM
MatthewFarnham
Hi all,
I have found a way to generate depth values based on floodmap extents in raster format and associate that to a building shapefile. Attached, I have provided the "fake" building outlines with the corresponding depth values.
I need to find a way to create another column (text I would assume), which essentially takes the depth values and makes it correspond to the following scale:
0-0.5
0.5-1
1-1.5
1.5-2
2-2.5
2.5-3
3+
The output will have something like this:
Column A: Buildings
Column B: Max actual Depths per Building
Column C: Scale
So, in the case of the example, the value of "0.1527" would correspond to the scale "0-0.5"
I hope this makes sense.
Any questions, let me know and if you require any further information, please do not hesitate!
Thanks!
Matthew
