calculating Minutes
841
11-20-2019 12:50 AM
Pianos_GeraldManjera
Anyone with an idea on how to write a function that can generate number of minutes covered between start time and end time. This should be in its own field
DougBrowning
MVP Esteemed Contributor
Like this (just switch out the now)
round(int(now() - ${StartedForm}) div (1000*60),1)
LS-SD
This works except when my survey is opened on a browser I can't display the elapsed time. It's not saving the value. I show the survey when testing in survey123 connect and then the published survey on the browser. HELP?!?
