Print Widget support for highlighting features
1330
11-18-2019 11:54 PM
MarkusÅfelt
Currently Print Widget (ArcGIS JS 4.13) does not support highlighting features?
Arcgis Server supports it (selectionObjectIds), ExportWebMap specification—Documentation (10.7) | ArcGIS Enterprise
So would it be possible get support for highlighting the features? or is there workaround getting it working?
Br,
Markus
Noah-Sager
Hi Markus.
You are correct, the print widget does not support printing highlighted features. One possible workaround would be to use the MapView.takeScreenshot() method instead of printing.
MapView | takeScreenshot()
Another possible workaround would be to add a copy of the feature as a Graphic before printing.
Hope this helps.
MarkusÅfelt
I went solution of copying the objectIds of highlighted features in the client side and sending those to backend.
In the backend, I modified the query for ExportWebMap by populating selectionObjectIds array from the values which I got from client side.
Now highlighting features is working fine on the print.
