Converting Feet and inches e.g. 5' 10" to whole number inches...
2064
11-17-2019 03:57 PM
JoshuaAdams1
I have a field "height" and its in x" y' . I need to convert this to inches and then multiple by 2.54 to update "height_cm" field.
DanPatterson_Retired
Nothing like a brain warmup before going to sleep;)
If you have any blanks or nulls, I don't check for them so only run this in the field calculator for valid heights
The result is a number, if you want a string replace line 7 with
return str((a + b) *2.54);‍
# ---- python code block section
def metric_is_better(val):
    r"""convert from 6' 2" to metric"""
    ft, inch = val.split(" ")
    a = int(ft[0]) * 12
    b = int(inch[0])
    return (a + b) *2.54
# expression
metric_is_better(!YourFieldName!)
Example...
Yes... this is how you have to encode when you use
' and " in strings
val = r"""6' 2\""""
val
'6\' 2\\"'
187.96  # the result‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaAdams1
How would this work for a list of attributes (entire table)? Goal is to not alter the height column but to read the imperial units x'x" in column height and populate another column height_cm
Using Calculate Field
Calculate Field—Data Management toolbox | ArcGIS Desktop
with the Python parser and a code block
