Layer: Unexpected error in replaceDataSource in SDE_WORKSPACE
2460
11-08-2019 05:32 AM
JohnCuthbertson1
ESRI 10.5
I have an MXD file with a single layer pointing to an SDE Feature class and I want to point to an SDE Feature class with a different name
C:\Temp\jc_mxd\AppsInternal\simple.mxd
Layer name =SDI.MTD.LAYER
dataSource =c:\temp\SDI.sde\SDI.MTD.LAYER
baseName       :SDI.MTD.LAYER
CatalogPath    :C:\Temp\SDI.sde\SDI.MTD.LAYER
dataElementType:DEFeatureClass
DataType       :FeatureClass
extension      :
file           :SDI.MTD.LAYER
path           :C:\Temp\SDI.sde
  File "mxd5.py", line 22, in <module>
    lyr.replaceDataSource ("c:\temp\SDI.sde","SDE_WORKSPACE","MTD.NEW" )
  File "D:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\utils.py", line 182, in fn_
    return fn(*args, **kw)
  File "D:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\_mapping.py", line 682, in replaceDataSource
    return convertArcObjectToPythonObject(self._arc_object.replaceDataSource(*gp_fixargs((workspace_path, workspace_type, dataset_name, validate), True)))
ValueError: Layer: Unexpected error
Source code:
import arcpy,os
conn_Input = r"C:\Temp\SDI.sde"
arcpy.env.workspace = conn_Input
inmxd = r"C:\Temp\jc_mxd\AppsInternal\simple.mxd"
mxd = arcpy.mapping.MapDocument(inmxd)
for lyr in arcpy.mapping.ListLayers(mxd):
 if lyr.supports("DATASOURCE"):
  dataSource = lyr.dataSource
  print inmxd
  print "Layer name =" + lyr.name
  print "dataSource =" + lyr.dataSource
  desc = arcpy.Describe(lyr.name)
  print("Name           :" + desc.name)
  print("baseName       :" + desc.baseName)
  print("CatalogPath    :" + desc.catalogPath)
  print("dataElementType:" + desc.dataElementType)
  print("DataType       :" + desc.dataType)
  print("extension      :" + desc.extension)
  print("file           :" + desc.file)
  print("path           :" + desc.path)
del mxd
JohnCuthbertson1
OK, I found it !!
should have been
lyr.replaceDataSource ("c:\\temp\\SDI.sde","SDE_WORKSPACE","MTD.NEW" )
Stupid mistake, not helped by vague error message
JohnCuthbertson1
OK, I found it !!
should have been
