Can I add a tpk layer to an ArcPro map through arcpy?
546
11-05-2019 08:43 AM
AdamStewart
I can open a project, select a map, and add data from path to bring in a tpk of World Street Map (for export).  However, if there is a method to do this process from arcpy, I'm unable to locate it.  I expect there's some type of import happending on the back end before it is brought into Pro.
    map.addDataFromPath
doesn't work.  Is this possible?
