Dynamically define parameters in a python toolbox
2610
11-04-2019 09:21 AM
Torbjørn_EidsheimBøe
Is it possible, in a python toolbox, to define a parameter (arcpy.Parameter()) in def updateParameters() or somehow define parameters so that both number (of parameters) and values (in parameter) is dependent on user input in first parameter?
DanPatterson_Retired
Not sure about the number of parameters but parameter values can be changed using 'altered'
Customizing tool behavior in a Python toolbox—Geoprocessing and Python | ArcGIS Desktop
Thanks for reaching out.
I tried defining all paramters "statically" in def getParameterInfo, but setting enabled=False to the ones i do not want to show up. Then in def updateParameters i tried to set enabled = True, and displayName = 'New_name' (displayName will be dependent on the data the user chooses). Only setting enabled = True works. Trying to change displayName in this way gives an AttributeError. Being able to change displayName would help avoid defining a lot of different parameters in getParameterInfo i think.
Something like this in updateParameters:
if parameters[2].valueAsText:
   parameters[3].enabled = True
   parameters[3].displayName = 'New_name'
Obviously not the way to do it. Not sure I understand how to use 'altered' in this case. Any pointers?
