Using Geoprocessing API to convert Feature Class to Shapefile
3597
10-28-2019 07:40 AM
RawMcGee
Can anyone explain to me how I can use the Geoprocessing API to export a feature class in the currently open map as a shapefile feature class? For one the Geoprocessing calls require a tool name, which is just a string, and I'm not sure where I'd find this information.
I'd also like to know what functions I should call to get symbology definitions for said feature class.
Basically in my add-in I want to the user to be able to select a layer in the current map via some tree view (which I already have working), and then they can click Export which will export said layer as a shapefile with associated symbology. I had this working with ArcObjects but I'm not sure how it is done with ArcGIS Pro.
UmaHarano
Here is a sample that shows you how you get the JSON representation of a Symbol. You can also get thte XML representation of the symbol by using the CIMSymbol.ToXML method instead.
SymbolLookup sample
Uma
RawMcGee
To answer my own question, this is the easiest way to convert a layer to a shapefile.
        protected async Task<string> ConvertShp(string layerpath, string outpath)
            if (!System.IO.Directory.Exists(outpath))
                System.IO.Directory.CreateDirectory(outpath);
            var valueArray = await QueuedTask.Run(() =>
                //input layers list should contain the path of each layer name, i.e. if the root node is "Mapping" and the layer name is "gs_points", path is "Mapping\\gs_points".
                List<string> inlayers = new List<string>();
                inlayers.Add(layerpath);
                //outpath is just the folder to save the shapefiles in
                return Geoprocessing.MakeValueArray(inlayers, outpath);
            // to let the GP tool run asynchronously without blocking the main thread
            // use the GPThread option of GPExecuteToolFlasgs
            GPExecuteToolFlags flags = GPExecuteToolFlags.GPThread;  // instruct the tool run non-blocking GPThread
            IGPResult gpResult = await Geoprocessing.ExecuteToolAsync("FeatureClassToShapefile_conversion", valueArray, null, null, null, flags);
            return string.IsNullOrEmpty(gpResult.ReturnValue)
                  ? $@"Error in gp tool: {gpResult.ErrorMessages}"
                  : $@"Ok: {gpResult.ReturnValue}";
I am still trying to figure out how to export symbology though. Meaning I need some way to enumerate through the symbol definitions for a specified feature layer. So that I can write it out in the format I need (XML).
It basically looks like Geoprocessing is a wrapper for ArcPy stuff? I'm not sure how I'd do more granular modifications to the data when exporting. If I wanted to change a column name or something, seems like there is no easy way to do it.
UmaHarano
SymbolLookup sample
Uma
