Make query layer returns 0 records, both from toolbox and arcpy.
1516
10-18-2019 04:43 PM
ScottBridwell
Is this a known issue? The same exact code works in ArcMap 10.7.1 toolbox and arcpy.
JoshuaBixby
MVP Esteemed Contributor
What you describe would be a huge issue if it broadly applied to ArcGIS Pro, so I am guessing it is something specific to your data sets or parameters.  Can you provide some more specifics on what data sources are involved and the syntax you are using to call/use the tool?
ScottBridwell
Looks like in the ArcPro version, there is an additional parameter called spatial_properties, that wasn't in the ArcMap version.
Setting this property seems to resolve my issue, e.g:
arcpy.MakeQueryLayer_management(
    my_db_conn,
    'layer',
    'select * from my_table',
    oid_fields='objectid',
    spatial_properties='DO_NOT_DEFINE_SPATIAL_PROPERTIES'
I guess in ArcMap the default behavior was to not provide spatial properties whereas in ArcPro the default behavior assumes you will provide them.
