Deploying Export Network as a service
1842
10-16-2019 11:41 AM
Labels (2)
ColinSchut
Hi all,
I am currently attempting to publish the export network tool as a service so it can be called by external software. Publishing the geoprocessing service is fine, but the output is a zip file. Trying to include the tool in a script that can unzip the file fails because arcpy has no ExportNetwork object. Is the tool being deprecated/not supported? Are there other workflows that may be more appropriate?
We've also had issues with using a service published directly from the ALRS network, and I thought this might be an easier solution for our needs...
AmitHazra
Hello Colin
The easiest way to access this GP Tool is to add it to a custom toolbox and then reference that toolbox in your python code.
1) Create a new toolbox: http://desktop.arcgis.com/en/arcmap/latest/analyze/managing-tools-and-toolboxes/creating-a-custom-to...
2) Right click the toolbox and add a new  built-in tool: http://desktop.arcgis.com/en/arcmap/latest/analyze/managing-tools-and-toolboxes/adding-tools.htm#GUI...
3) Browse to your installation of Roads and Highways Desktop and look for the Location Referencing Tools:  Ex: C:\Program Files (x86)\ArcGIS\LocationReferencing\Desktop10.7\ArcToolBox\Toolboxes
4) Check the Export Network GP Tool to add it to your new toolbox
Now you can access this toolbox through some super basic Python like this:
arcpy.ImportToolbox('C:\GISTemp\MyToolbox.tbx', 'LrsTool')‍
arcpy.LrsTool.ExportNetwork(add your GP arguments here...)
Good luck,
Amit@Esri
AmitHazra
Hello Colin
Good luck,
Amit@Esri
ColinSchut
I get the error:
"Traceback
<module>
TypeError: ExportNetwork() takes no arguments (9 given) "
when trying this with the ExportNetwork tool. It did work with another tool (I tried it with Buffer).
Putting the tool in a model and trying to run it that way returns a tool is not valid error.
AmitHazra
Hello Colin - Export Network is expecting up to 9 arguments:
When you open the parentheses on the tool it should look similar to:
-Amit@Esri
