Attachment Viewer - No attachments found
3129
8
10-15-2019 07:11 AM
RobertThomson
The layer I am trying to display works fine in a web map on AGOL and my desktop.  Attempting to create a web app with Attachment viewer always give "No attachments found".
SarahMcDonald_Esri
Hi Robert,
Thank you for reaching out. Is the feature service that is being used in the application coming from ArcGIS Server/Portal for ArcGIS or ArcGIS Online?
Thanks!
Sarah
RobertThomson
It's from ArcGIS Online.
SarahMcDonald_Esri
Hi Robert,
Got it, would you be able to provide the link to the application or the web map being used?
Thanks!
Sarah
RobertThomson
SarahMcDonald_Esri
Hi Robert,
Thanks for providing the application. I did some testing with the application and was able to see the issue that you are seeing as well. I found that the attachments would not be recognized in the attachment viewer application when there was a map server service in the map, even if this isn't the layer with attachments. I went into my map and adjusted the URL for the map server to reference a direct item in the service, for example: https://<Server_URL>/arcgis/rest/services/<Service_Name>/MapServer/0
Rather than using the map server URL like this: https://<Server_URL>/arcgis/rest/services/<Service_Name>/MapServer
Can you try that adjustment and let me know if that helps the application to recognize the attachments in the water curb stop valves layer?
Thanks!
Sarah
RobertThomson
Adding /0 to the end of the URL without a space did the trick.  Thanks.
ProfFerideSchroeder
How do you adjust the URL?  Thanks!
Seanrobison1
I am having the same problem.  How did you adjust the URL?
