Invalid MXD filename error
5374
11
03-14-2011 04:17 PM
JasonHarshman
I'm trying to modify a python script that was provided by Esri in the sample arcpay mapping script tools. I'd like to export a PDF for each MXD selected instead of exporting multiple MXDs to a single PDF. Below is the Esri version and beneath that is my version. I feel like I'm doing everything right, but obviously I'm missing something. Any guidance is greatly appreciated.
# Author:  ESRI
# Date:    July 5, 2010
# Version: ArcGIS 10.0
# Purpose: This script will export multiple map document layoutinto a single
#          output PDF file. The script is intended to run within a script tool.  There are two
#          parameters:
#               1) Select Map Documents to Append,
#               2) Output PDF.
#Notes: The order of the MXDs is based on how they are entered.  The MXD at the
#       top of the list is first followed by those below it.
import arcpy, os, string
#Read input parameters from script tool
mxdList = string.split(arcpy.GetParameterAsText(0), ";")
outPDFpath = arcpy.GetParameterAsText(1)
#Create a new PDF object to store the results
outputPDF = arcpy.mapping.PDFDocumentCreate(outPDFpath)
#Loop through each MXD in the list, export, create a temporary PDF name,
# and append to final, output PDF
for mxdPath in mxdList:
    mxd = arcpy.mapping.MapDocument(mxdPath)
    PDFPath = mxdPath[:-4] + "_temp.pdf"
    arcpy.mapping.ExportToPDF(mxd, PDFPath)
    outputPDF.appendPages(str(PDFPath))
#Save the changes and open the result automatically
outputPDF.saveAndClose()
os.startfile(outPDFpath)
#Remove variable reference to file
del outputPDF
#MY CODE
import arcpy, os, sys, string
#overwirte existing PDFs
arcpy.OverWriteOutput = 1
multimxds = string.split(arcpy.GetParameterAsText(0), ";")
outputfolder = arcpy.GetParameterAsText(1)
#set variable for PDF name
#trying to set folder path
folderpath = outputfolder
#export to pdf
#trying to export to pdf using title name and folder parameter
for mxdloop in multimxds:
    mxd = arcpy.mapping.MapDocument(mxdloop)
    name = mxd.title
    pdf = folderpath + '\\' + name + ".pdf"
    arcpy.mapping.ExportToPDF(mxd, pdf, 'PAGE_LAYOUT', 640, 480, 400)
#delete folderpath variable
del folderpath
JasonScheirer
Esri Alum
Could you post the error messages?
JasonHarshman
Hi Jason,
This is the error I receive in PythonWin. Attached is a screen shot of the error I receive when running the script as a tool.
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 325, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\Documents and Settings\Harshman\Desktop\PDF Loop Test\ExportMXDToPDF_LOOP.py", line 16, in <module>
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\mixins.py", line 443, in __init__
    assert (os.path.isfile(mxd) or (mxd.lower() == "current")), gp.getIDMessage(89004, "Invalid MXD filename")
AssertionError: Invalid MXD filename.
Thank you.
JasonScheirer
Esri Alum
Could you put an AddMessage in your loop to see what file it's failing on?
#MY CODE
#export to pdf
    arcpy.AddMessage("Opening map document %s" % mxdloop)
    name = mxd.title
JasonHarshman
It fails on the first MXD selected in my parameter, but it doesn't seem to matter what MXDs I select or in what order I select the MXDs. It always fails on the first one.
JasonScheirer
Esri Alum
Could you post the output from the geoprocessing window?
JasonHarshman
Jason,
Attached is a screen shot of the GP window. Like I said, it fails on the first MXD in the list. Thanks for your help.
JasonScheirer
Esri Alum
Ah, I see now. Need to strip the quotes.
multimxds = [filename[1:-1] for filename in string.split(arcpy.GetParameterAsText(0), ";")]
JasonHarshman
I'm not sure I follow. I stripped the quotes and got an invalid syntax error. I used single quotes and got the same invalid MXD error. I inserted the code snippet you provided and i still received the invalid MXD error.
This is what I have:
#export to pdf
    name = mxd.title
del folderpath
JuanOrozco
Is failing because your MXD path has spaces in it.
