Hi, i have been working on get minimum bounding rectangle for my building polygons using python. i do get square rectangles but i need minimum rectangles to train YOLOv3. Thanks in advance.
1592
10-13-2019 08:05 AM
rizwangul
It is a project to extract building footprints using instance segmentation in machine learning techniques. but i need minimum bounding rectangles to separate each building polygon from other connected building polygon to treat each polygon as a single class. MBRs are things which need. can anyone help how i can get it in python. i have rectangles but those are squares and not minimum. thank you.
DanPatterson_Retired
Minimum bounding rectangles, sometimes go by rectangle by area...
In any event, they are all here IF! you have the appropriate license level
Minimum Bounding Geometry—Data Management toolbox | ArcGIS Desktop
If not, then you can steal the code from
https://www.arcgis.com/home/item.html?id=564e2949763943e3b9fb4240bab0ca2f
for the minimum area bounding rectangle
