dynamic text no gaps in lines if one line not displayed
1452
10-11-2019 03:02 AM
DionKerasidis
I am trying to set up a dynamic text for reading data from DDP. will have 4 lines. depending on the DDP some lines might be empty and not showing anything. In that case i was the next line to take its place and have no gaps in between lines. See below an example
COUNTY OF
DISTRICT
PARISH
DRAWING
if parish does not exist want this to look like
COUNTY OF
DISTRICT
DRAWING
if nothing exist then only DRAWING should be shown (this is only text ) on the top, where COUNTY OF would normally be placed.
Thank you
RobertBorchert
Honored Contributor
Set up label rules.
example only show the four line label if all four fields are not null.
For the 3 line labels set on of for each possible occurrence if necessary.
line1 is not null and line2 is not null and line3 is null and line4 is not null
etc...
DionKerasidis
How do i set rules in dynamic text?
RobertBorchert
Honored Contributor
In your Pro Project or MXD
Which software are you using?
DionKerasidis
Hi Robert
i am using 10.3. This is what i am getting. All i need is the last line to get the place of the previous one if no entry exist.
