How to georeference an image in arcgis local server (offline)
1328
10-13-2019 04:14 AM
Sharan_saiGudibanda_Nagesh
I have  a jpeg map, I would like to make georeference image from that map and use it as a base map, this entire thing should be done offline.  If it's okay provide me required resources @
MichaelBranscomb
Esri Frequent Contributor
Currently the API doesn't include direct support for georeferencing an image on-the-fly. For a suggested workflow see this similar question: Georeference option in Runtime.
You can find more information about World Files in World files for raster datasets—Help | ArcGIS Desktop.
If your workflow involves KML, you might also consider using KML GroundOverlays: for a sample see Edit KML ground overlay | ArcGIS for Developers
Cheers
Mike
Thanks for reply, will try to figure it out
