Feature color change when base map changes
716
10-04-2019 08:14 AM
RobertBorchert
Honored Contributor
Is there any setting to automatically change the color of specific features when the base map changes.
We have a web map we call our Standard Web Viewer. It is visible to all employees. Section lines by default are turned off.  When you turn them on they are black dashed lines.   The Base by default is Topographic.  However, our surveyors often switch to Air Photo  and the section lines are not visible or are very hard to see.
So, is there a way such that when the base is changed that the colors for select features change?
