Problem using intersect tool
763
10-01-2019 06:31 PM
SarahFischer
    I have a map where I have two point layers (representing bird surveys in a given year) overlaid by a 1km x 1km grid (polygon) that divides my study area into habitats.  I want to be able to select those grid cells where I have points from both point layers (so, points for each year) to compare data.  I thought using the intersect tool would be the best way to go about this but I continually get the below error:
WARNING 000117: warning empty output generated
Any suggestions would be welcomed; I'm not even sure if intersect is the best tool to use for something like this.
Kind Regards
Sarah Fischer
PhD student Charles Darwin University
DanPatterson_Retired
000117: Warning empty output generated.—Help | ArcGIS Desktop
which could arise from a wrong extent being set within the environments of the tool, or differences in the coordinate systems.
