Error occurred when rendering by the report engine. Failed to parse ${ _237_Hazard_Reports.irrigated|getValue:"("")==("irrigated")"}
786
09-29-2019 11:10 PM
OussamaMerhi
Suddenly some function stopped working in the feature report and gives an error: Error occurred when rendering by the report engine. Failed to parse ${ _237_Hazard_Reports.irrigated|getValue:"("")==("irrigated")"}
The function is:
${if irrigated|getValue:""== "irrigated"}  كلا ${/}
Tags (1)
by Anonymous User
Not applicable
Survey123 for ArcGIS‌ might be able to assist better here.
-Peter
JamesTedrick
Esri Esteemed Contributor
Hi Oussama,
Can you provide more details on the ${irrigated} question?  It looks like you are combining syntax that would be used with an image along with syntax for a single choice question.
