Hosted Feature Layer String Field Indexing Fail
1305
09-26-2019 09:54 AM
SangHyouk_Oum
I am trying to set an index on string field and it fails with following error:
Column 'COUNTY' in table 'db_45156.user_45156.SWITRS_20190830_PRO_SWITRS_20190830' is of a type that is invalid for use as a key column in an index.
(Error Code: 400)
I have been using the same column for indexing years without an issue. Is this no longer supported?
by Anonymous User
Not applicable
Hi Sang Hyouk Oum‌,
Setting a unique index on a text field is still supported - "you can set a unique constraint on any field type except system fields such as ObjectID, GlobalID, and FID." Are you setting the index in ArcGIS Online following this workflow: Add a unique constraint to a field—ArcGIS Online Help | ArcGIS
If you can send a zipped FGDB of your data to [email protected]m I would be happy to publish a Hosted Feature Layer on my end and see if I run into the same error when creating the index.
Hope this helps,
Peter
