Query for orginal numbers
4088
26
09-23-2019 03:48 PM
CCWeedcontrol
I am trying to query a filed to find original parcels, i would like to create a filled and mark the ones that are original and don't have not split. Currently the field is a string with a length of 11. Some parcels have 5, some 8 and some 10 - not including the alph letter. Hopefully i have explained good what I am needing, i am just not sure how to do this. At first i thought of doing unique numbers but some how it would need to know if the first 5 digits are used, there are some duplicate numbers as well. I am kind of lost on how to proceed, if anyone has done something similar could share some code please?
the attributes are as follows for example;
R00062 (Original parcel)--> has R00062010 (Split parcel, next one below) - this is not one i need marked.
R00062010 - Not Original parcel
R32073114 - Not Original parcel
R32078 - Original parcel because there is no other parcel number associated with it, need this one mark in the new filed.
R32079 - Original parcel because there is no other parcel number associated with it,, need this one mark in the new filed.
R32081 - Original parcel because there is no other parcel number associated with it,, need this one mark in the new filed.
R32082012 - Not Original parcel
R32083012 - Not Original parcel
JoeBorgione
When you say 'Original parcel because there is no other parcel number associated with it'  how is that 'association' maintained?   Do you have a related table of the 'child' parcels? Is it maintained in the actual parcel data itself?
Is there some what to see what the parent parcel of R00062010 is? etc.....
CCWeedcontrol
Joe,
When a parcel is split for example, a split comes through for R00062, R00062 stays as the mother account and the new parcels (child parcels) get 010 or 011 or 012 etc. There is currently no efficient way of maintaining this data, one would just have to look to see of there is a R00062010 or R00062010 or R00062011 or R00062012 etc. This is not my data this is data i am working with.
RandyBurton
Is the original parcel always 6 characters?  If so, would slicing work?
>>> parcel = 'R00062010'
>>> original = parcel[:6]
>>> original
'R00062'
>>> subparcel = parcel[6:]
>>> subparcel
'010'
>>> len(subparcel)
CCWeedcontrol
Yes it's always 6 characters,  R00062 would seem like it's an original parcel but there could be R00062010 or R00062010 or R00062011 or R00062012 (These would be considered child parcels) but some how it needs to check to see if R00062 (6 characters) are used in other parcel numbers. This parcel would not be considered an original parcel because it's has child parcel numbers.
JoshuaBixby
MVP Esteemed Contributor
So you are really interesting in marking/finding all original parcels that were never split and thus have no children parcels?
CCWeedcontrol
Yes that is correct.
JoshuaBixby
Try:
import arcpy
from collections import Counter
tbl = # path to table containing parcels
parcel_count = Counter(
    (pid[:6] for pid, in arcpy.da.SearchCursor("tbl","PARCEL_NO"))
for pid,cnt in parcel_count.items():
    if cnt == 1:
        print(pid)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
CCWeedcontrol
Joshua, i appreciate the help. I am getting error, see below. Also how can i get this to this to put a mark in a another field vs just printing them?
line 10, in <module>
AttributeError: 'generator' object has no attribute 'items'
import arcpy
tbl = 'C:/Temp/ParcelNumberSample2.dbf'
parcel_count = (
    (pid[:6] for pid, in arcpy.da.SearchCursor(tbl,"PARCEL_NO"))
    if cnt == 1:
        print(pid)
JoshuaBixby
My bad, i left out of function call, I just edited my earlier code.
