Fill table with update cursor? array?
3415
6
09-20-2019 12:24 AM
JohannesBierer
I have problems to update two attribute fields with values created in the following code. The insert cursor works well but with the update cursor I get a error message. Are there any other ways to fill a table with values?
Error message:
line 60, in UpdateFields
    cursor.updateRow([row])
StopIteration: iteration not started
# -*- coding: cp1252 -*-
import arcpy, os
myPath = r"R:\Daten\geo_daten\Arten\Fledermaeuse\AltDaten"
out_path_table = r"C:\temp4\Geodatenbestand.mdb"
out_name_table = "Geodatenbestand"
template_table = r"C:\temp4\Geodatenbestand.mdb\Geodatenbestand_Template"
inTable = os.path.join(out_path_table, out_name_table)
inTableL = "Table_Layer"
MyList1 = list()
MyList2 = list()
# Encoding der Standardausgabe herausfinden
stdout_encoding = sys.stdout.encoding or sys.getfilesystemencoding()
class Geodatenbestand(object):
    def __init__(self):
        self.myPath = myPath
    def SearchFiles(self):
        SHPCounter = 0
        for path, dirs, files in os.walk(myPath):
            for file in files:
                if file.lower().endswith('.shp'):
                    print path + "\\" + file
                    SHPCounter += 1
                    print SHPCounter
                    accessTime = os.path.getatime(os.path.join(path, file)) # last access time
                    actualTime = time.time()
                    hoursPassed = """{}""".format(int((actualTime - accessTime)/3600))
                    path1 = path.decode(stdout_encoding)
                    file1 = file.decode(stdout_encoding)
                    print file1
                    cursor = arcpy.da.InsertCursor(inTable, ['PathFile'])
                    cursor.insertRow([path1 + "\\" + file1])
                    MyList1.append(file1)
                    MyList2.append(hoursPassed)
    def UpdateFields(self):
        print MyList1
        with arcpy.da.UpdateCursor(inTable,["File"]) as cursor:
            for row in MyList1:
        print MyList2
        with arcpy.da.UpdateCursor(inTable,["h_not_used"]) as cursor:
            for row in MyList2:
    def CreateTable(self):
        if arcpy.Exists(inTable):
            arcpy.Delete_management(inTable)
        arcpy.CreateTable_management(out_path_table, out_name_table, template_table)
if __name__ == '__main__':
    MyClass = Geodatenbestand()
    MyClass.CreateTable()
    MyClass.SearchFiles()
    MyClass.UpdateFields()
JoshuaBixby
MVP Esteemed Contributor
Actually, your code is worse than you think.  You are writing, and overwriting, each and every value in MyList1 into each and every row in cursor.  Since the last value isn't overwritten, that is what you are seeing in each row after the update cursor is complete.
Assuming the cursor and list are the same length, and the cursor will iterate in the same order as the list, which is a risky assumption when not using a SQL ORDER BY clause, you could go with:
    for value in MyList1:
        next(cursor)
        cursor.updateRow([value])
JohannesBierer
If you use a array, how to fill a column in an array with a list? This doesn't work:
        inArray = numpy.array([(MyList, MyList1, MyList2)],
                      numpy.dtype([('Path_File', '|S256'),
                                   ('File', '|S256'),
                                   ('h_not_used', numpy.int32)]))
        arcpy.da.NumPyArrayToTable(inArray, outTable)
Error message:
line 63, in UpdateFields
ValueError: cannot set an array element with a sequence
JoshuaBixby
For NumPy, try this:
    [(i,j,k) for i,j,k in zip(MyList,MyList1,MyList2)],
    numpy.dtype([('Path_File', '|S256'),('File', '|S256'),('h_not_used', numpy.int32)])
JoshuaBixby
Simply looking at this error:
Error message:
In Line #57, you instantiate the cursor but you never start iterating through it.  Whereas most or all geoprocessing tools work on sets of data, ArcPy cursors work on individual rows of data.
You will run into the same error on Lines #64-#67.
JohannesBierer
Yes OK.
If I write it like this it overwrites all rows with the last value in MyList1. Don't really know how to get it to write exactly each row in the list into the right row in the table?
        print MyList1
            for row in cursor:
                    print value
JoshuaBixby
        next(cursor)
JohannesBierer
Thank you ...
