How to Send Parameter to SOE through HTTP based services?
4348
09-20-2019 10:01 AM
ShaikhRizuan
I am having "Location" parameter where 'x' & 'y' value has to pass in SOE to process the request.Below is the C# code to access the SOE request.
// Create a request using a URL that can receive a post.
WebRequest request = WebRequest.Create("https://myServer.com:6443/arcgis/rest/services/ITDService/MapServer/exts/DistanceSOE/SpatialQuery");
// Set the Method property of the request to POST.
request.Method = "POST";
// Create POST data and convert it to a byte array.
string postData = "{\"Location\": {\"x\": 84.44902820440936,\"y\": 21.300696836245145}}";
byte[] byteArray = Encoding.UTF8.GetBytes(postData);
// Set the ContentType property of the WebRequest.
request.ContentType = "application/x-www-form-urlencoded";
// Set the ContentLength property of the WebRequest.
request.ContentLength = byteArray.Length;
// Get the request stream.
Stream dataStream = request.GetRequestStream();
// Write the data to the request stream.
dataStream.Write(byteArray, 0, byteArray.Length);
// Close the Stream object.
dataStream.Close();
// Get the response.
WebResponse response = request.GetResponse();
// Display the status.
Console.WriteLine(((HttpWebResponse)response).StatusDescription);
// Get the stream containing content returned by the server.
// The using block ensures the stream is automatically closed.
using (dataStream = response.GetResponseStream())
// Open the stream using a StreamReader for easy access.
StreamReader reader = new StreamReader(dataStream);
// Read the content.
string responseFromServer = reader.ReadToEnd();
// Display the content.
Console.WriteLine(responseFromServer);
It is going to SOE but could not able to read the "Location" Parameter and its values. PFB image for the same.
Can anyone let know, how parameters need to be send?
nicogis
private RestResource CreateRestSchema()
            RestResource rootRes = new RestResource(soe_name, false, RootResHandler);
            RestOperation sampleOper = new RestOperation("sampleOperation",
                                                      new string[] { "Location" },
                                                      new string[] { "json" },
                                                      SampleOperHandler);
            rootRes.operations.Add(sampleOper);
            return rootRes;
JsonObject parm1Value;
bool found = operationInput.TryGetJsonObject("Location", out parm1Value);
if (!found)
    throw new ArgumentNullException("Location");
IPoint location = Conversion.ToGeometry(parm1Value,
        esriGeometryType.esriGeometryPoint) as IPoint;
when you call soe you an write similar code:
void Main()
	Location location = new Location() { x = 100.3d, y = 500.9d };
	JavaScriptSerializer js = new JavaScriptSerializer();
	string jsonData = js.Serialize(location);
	Dictionary<string, string> dictionary = new Dictionary<string, string>();
	dictionary.Add("f", "json");
	dictionary.Add("Location", jsonData);
	Request.HttpPost("http://...../MapServer/exts/TestSOE/sampleOperation", dictionary);
internal class Location
	public double x;
	public double y;
/// <summary>
/// class request rest
/// </summary>
internal static class Request
	/// <summary>
	/// method http get
	/// </summary>
	/// <typeparam name="T">object T</typeparam>
	/// <param name="url">url for get</param>
	/// <returns>return object T</returns>
	public static T HttpGet<T>(string url)
		string result = Request.HttpGet(url);
		var serializer = new JavaScriptSerializer();
		var deserializedResult = serializer.Deserialize<T>(result);
		return deserializedResult;
	/// <summary>
	/// method http get
	/// </summary>
	/// <returns>return response</returns>
	public static string HttpGet(string url)
		HttpWebRequest req = WebRequest.Create(url) as HttpWebRequest;
		req.Method = WebRequestMethods.Http.Get;
		string result = null;
		using (HttpWebResponse resp = req.GetResponse() as HttpWebResponse)
			StreamReader reader = new StreamReader(resp.GetResponseStream());
			result = reader.ReadToEnd();
		////Request.CheckError(result);
		return result;
	/// <summary>
	/// method http post
	/// </summary>
	/// <param name="url">url for post</param>
	/// <param name="parameters">parameters post</param>
	public static T HttpPost<T>(string url, Dictionary<string, string> parameters)
		string result = Request.HttpPost(url, parameters);
	/// <summary>
	/// </summary>
	public static string HttpPost(string url, Dictionary<string, string> parameters)
		HttpWebRequest req = WebRequest.Create(new Uri(url)) as HttpWebRequest;
		req.Method = WebRequestMethods.Http.Post;
		req.ContentType = "application/x-www-form-urlencoded";
		string queryString = string.Join("&", parameters.Select(x => x.Key + "=" + HttpUtility.UrlEncode(x.Value)));
		// Encode the parameters as form data:
		byte[] formData = UTF8Encoding.UTF8.GetBytes(queryString);
		req.ContentLength = formData.Length;
		// Send the request:
		using (Stream post = req.GetRequestStream())
			post.Write(formData, 0, formData.Length);
		// Pick up the response:
		return result;
	/// <summary>
	/// verifica se il result ha un messaggio di errore. Nel caso getta un'eccezione
	/// </summary>
	/// <param name="result">result da analizzare</param>
	////private static void CheckError(string result)
	////    ErrorRest.ErrorRest error = JsonConvert.DeserializeObject<ErrorRest.ErrorRest>(result);
	////    if (error.error != null)
	////        string details = string.Join(",", error.error.details);
	////        throw new Exception(string.Format("Error code: {0} - Messaggio: {1}{2}", error.error.code, error.error.message, string.IsNullOrEmpty(details) ? string.Empty : string.Format("- Dettagli: {0}", details)));
ShaikhRizuan
Thanks Domenico.. It helps!!
