python - merge polys in arcmap
3943
7
09-18-2019 12:38 PM
GailMorrison
Greetings!  I have feature data sets that have 1+ polys. The ArcMap merge tool works great. How do I script this type of processing using Python?
Thx! Gail
Jeremy_Moore
Take a look at arcpy.Merge_management() which will combine your FeatureClasses into one FeatureClass as a single polygon
Merge—Data Management toolbox | ArcGIS Desktop
You could also use arcpy.Append_management() however this will combine your FeatureClasses into a single FeatureClass without merging into a single polygon.
Append—Data Management toolbox | ArcGIS Desktop
Then if you needed to combine features in a FeatureClass into a single polygon you want to use arcpy.Dissolve_management()
Dissolve—Data Management toolbox | ArcGIS Desktop
3 different tools that do essentially the same thing visually on different data types.
If you need help on how to use these tools please don't hesitate to ask. There are no dumb question.
Hope this helps
GailMorrison
I don't think I asked the question correctly.  The above answer is for merging datasets.  I need a script to merge polygons within each dataset.
Jeremy_Moore
Just to make sure we are on the same page:
When you say dataset are you referring to a feature dataset, which is a collection of related feature classes that share a common coordinate system? Or are you referring to polygon features in a single feature class?
I apologize if I'm being dense
GailMorrison
Oh, you are not being dense.  I am being sloppy with my verbaige.  I  am referring to polygon features in a single feature class
Jeremy_Moore
Alright, so polygon features in a feature class. You would want to use arcpy.Dissolve_management()
If you need a code example let me know.
GailMorrison
The catch is that I need to keep all the fields in the attribute table. Unless I calculate all the field values to be the same, this won't work for what I need.  Example:  Fields = sqmi, sqft, sqkm, name.  If I dissolve on Name, the other 3 fields drop out of the feature class.
Jeremy_Moore
Sorry for the delay in getting back to you. I have been playing around with some other tools to try to find a solution for you. Once the geometry has been combined and the attributes limited down to a single row, do you need any information in that row?
I have been able to preserve your fields. Try this script and see how it works for you
import arcpy
inFeatureClass = r"C:\Users\JohnDoe\Documents\ArcGIS\Projects\General\General.gdb\dissolve_polygons"
outFeatureClass = r"C:\Users\JohnDoe\Documents\ArcGIS\Projects\General\General.gdb\dissolve_test"
listFields = arcpy.ListFields(inFeatureClass)
print("Dissolving polys")
arcpy.Dissolve_management(inFeatureClass, outFeatureClass)
print("Adding Fields")
for addField in listFields:
    try:
        arcpy.AddField_management(outFeatureClass, addField.name, addField.type, "", "", addField.length, "", "", "")
    except:
        continue
