In need of feature class example for Solar Generation
1470
5
09-17-2019 07:02 AM
by Anonymous User
Not applicable
Are there any examples out there of a feature class for Solar Generation?  I need to create a new feature class for a solar field and rooftop solar arrays for our Public Works Electric Division and I want to be sure I am capturing all of data that I can.
by Anonymous User
Not applicable
by Anonymous User
Not applicable
Thank you Manoj.  I will look into it!
by Anonymous User
Not applicable
Hi Brenda,
Is it helpful? Then mark it yes.
Regards,
Manoj Patil | Senior Consultant
Esri Australia | Level 3, 111 Elizabeth Street | Brisbane, QLD 4000 | Australia
T +61 (0)7 3218 4164 | M 0437 3480 45 | mpatil@esriaustralia.com.au<mailto:mpatil@esriaustralia.com.au> | esriaustralia.com.au<http://www.esriaustralia.com.au/>
Blog: esriaustralia.com.au/blog<http://www.esriaustralia.com.au/blog>
by Anonymous User
Not applicable
I have not looked into it but I will mark it as helpful. Thank you.
JohnAlsup
esri provides a base model for electric that covers from generation to low voltage services and all the equipment inbetween, including solar, wind and other generation forms and includes the equipment specific to solar, like inverters. The Asset Package rename option can be used to change the names of elements to your local terms as longs as the device is used the same way, for example a Load Breaking device.  The model has been designed to leverage all the capabilities of the utility network and includes extensive documentation and diagrams on proper modeling techniques.  The model was designed to support Balanced and Unbalanced Polyphase systems, multiple frequency systems, support engineering analysis and multiple switching plans.
Electric Utility Network Foundation | ArcGIS Solutions for Electric
John Alsup
jalsup@esri.com
